This procedure does not apply to 5320 Series and 5420 Series.
Ensure that you enable DvR globally on the node.
Perform this procedure to view the remote DvR backbone members. DvR backbone members are either DvR Controllers or non-DvR BEBs that receive redistributed host routes from all other DvR Controllers in the SPB network.
- Select DVR Remote.
- Select the Backbone Members tab.
- Optional: To filter the rows based on specific criteria, select Filter.
Backbone Members Field Descriptions
Use the data in the following table to use the Backbone Members tab.
Name |
Description |
MacAddress |
Specifies the system ID or the nodal MAC address of this DvR backbone member. |
SysName |
Specifies the system name of this DvR backbone member. |
NickName |
Specifies the nickname of this DvR backbone member. |
Role |
Specifies the role of this DvR backbone member. It is either a DvR Controller or a non-DvR BEB. |
DomainId |
Specifies the domain ID of the DvR domain that this backbone member belongs to. The domain ID is 0 for a non-DvR BEB. |
